Technoull seaDNA999 2x275
Forum in lingua inglese per scambio esperienze con gli amanti del gommone da tutto il mondo
English-language section for experiences exchange with rib's passionate from all the word
Write in english
Scrivere in inglese
adventure47
Raid-Man
Re: Technoull seaDNA999 2x275
Messaggioda adventure47 » 04/07/2009, 14:02
All my compliments for new 888, i hope to test :d:
P.S. excuse my bad language... :oops:
Messaggioda Akeswins » 06/07/2009, 14:36
Adam,
I also saw the 888 in a youtube video. This rib is the fastest I've seen.
can you explain more about your " tapered steps"?
And a question about the 999 "double stepped": the keel has the same inclination, or the stepped part has a different angle?
Thanx
Adam Younger
Gommone: Aquavite 74 RIB
Motore: Yamaha 200
Messaggioda Adam Younger » 21/07/2009, 8:38
The tapered steps are my solution to getting stepped hull boats to handle better throughout the speed range and also in turns etc. Basically the depth of the step is greater at the centreline and becomes less towards the chine. It does not get all of the efficiency of soem racing steps - but the gains in handling more than make up for this in my opinion. Bit more to it - but can't give all my secrets away (§)
On the 999 the keel has slightly more angle of attcak over the step areas. This is more so on the 888. Both boats have exceeded their expectations for speed and really pleased with them from a design point of view. However must also say a lot of credit goes to the build from Technohull and really good hull finish and fairness of lines.
www.adamyoungerdesign.com
alexcacciafotosub
Messaggioda alexcacciafotosub » 12/08/2009, 11:19
Dear Adam, have no words! I like the simplicity of lines and covered both the aggressiveness of the water lines.
Simply amazing!
Welcome on board.
Alex
Johnson 140cv 4T
Sicilia Or.le e Isole Eolie
Il mio sito
Adam Younger
Motore: Yamaha 200
Messaggioda Adam Younger » 22/06/2010, 8:46
The latest 999 model and most likely the best one yet. Many extras and a few extra developments too.
Recently I had the pleasure to visit Technohull and we had some really good tests with this boat in fairly choppy water.
Turbopompa
Gommone: mar-sea cl35
Motore: Johnson 15cv 2t
Messaggioda Turbopompa » 22/06/2010, 17:51
:lov :lov magnificent!
Messaggioda Akeswins » 23/06/2010, 9:38
Adam Younger ha scritto:The latest 999 model and most likely the best one yet. Many extras and a few extra developments too.
I've seen a video in rough waters (on youtube) that shows the inboard diesel one.. very stable and also dry.
Torna a “Rib International”
